Bad start to the weekend...
Fresco3000
Post by Fresco3000 »
Thanks to a boy racer entering the roundabout at speed my former mint Mk2 requires some parts. I braked, swerved and clipped his bumper.
Painful insurance adventures ahead.
If anyone has the following parts at reasonable rates let me know.
Drivers front wing
Front bumper
Bonnet
Drivers front lamps
Hoping yours is better than mine.
1980 Mk1 Scirocco GLi / 1986 T25 Caravelle / 1989 Mk2 Scirocco GT
unknownmale
Re: Bad start to the weekend...
Post by unknownmale »
Bonnet looks fixable with a bag of sand (Not slang) and a mallet. The bumper could be too as it's likely just the metal bar thats bent, some heat and a big vice would straighten it which just leaves the wing and indicator at least
Fresco3000
Will try to fix those if possible, started looking for a donor car.
Nuckleduster
Post by Nuckleduster »
HI David,
I probably have lamp and indicator as I recently scrapped our J reg one and salvaged everthing I could.
The reinforced behind the bumper is a pig to get off the cover but would need to be separated to straighten out and rubberised cover placed back on. I cant help you with a bumper as I let it go to a register member along with the wings.
best wishes Gerry.
p.s. how hard did you thump the pyjama that caused it.
91 Scirocco Scala 1.8 inj rolling shell gone but not forgotten
90 Scirocco Scala 1.8 inj Colour Dark Metalic Green daily ride
Vw MK4 Golf Estate @180bhp Daily working car--Silver
94 Corrado 2.9 VR6 Metalic purple--gone to Manchester--
Fresco3000
Cheers Gerry,
Let me know, must have been about 10mph as I had braked and swerved. Still an expensive hit.
Nuckleduster
Def got light and indicator
Gerry
will double check but i think i have a drivers wing
Fresco3000
Cheers,
I’ve already picked up the lights.
Still need a bumper and wing tho....
i do have a drivers wing in badly faded red.
it has a dent in the arch bit but isnt catastrophic as it will be hidden behind the body kit.
gimme a pm if your interested
i also have a couple of bumper skins but no irons im afraid
Fresco3000
PM sent, pics of what you have would be appreciated!
Fresco3000
Thanks to all who have advised and been in touch.
Picked up all the parts, will attempt the fixing next week.
Ended up with a coloured bumper which i’ll have to spray black. Any advice on paint for this, so that it looks a bit plastic, non shiney, if that’s possible?
GT_II
Post by GT_II »
Alternatively, is there a solvent available that would strip the paint off without damaging the plastic?
Fresco3000
Good point, must say all my paint stripping experiences have been like sanding x100 in pain : /
unknownmale
You could just scuff it up with a scotchbrite pad, then use VHT Wrinkle paint on it, put a heat gun on it after each coat and it'll texture up like the OEM bumper. Thinner coats will product finer wrinkles, have a play around with it
