Back Screen Window Wiper Not Working .
I wonder if anybody can help me off here ? The back window wiper suddenly stop working on Sally . I have cleaned the circuit board and the relays . And replaced some them as this is a problem with the mk 2 as you can get water coming as the drain holes in the sunroof get blocked .
AM thinking I need to get a new relay for it as you get a clicking sound when you try to operate it and you can hear the electric power in the back wiper screen motor .
Many thanks to all that can help off here it is more then appercited .
- Site Admin
Re: Back Screen Window Wiper Not Working .
First port of call I would say would be use a multi meter and see how much power you are getting at the motor.
It could be the relay is on its way out but this is very unusual as they normally just die.
I’d suspect the motor.
I do have a full motor set up if you do need it later on just drop me a pm
Jack
South East
VW Scirocco Scala MK2 1.8 Inj
Jaguar F-Type
South East
Jaguar F-Type
- scrumpyone
I've got exactly the same problem. A sparky is checking mine out on Thursday, I'll let you know the outcome.
Dave
Register No:1110
'79 MK1 GLS (R.I.P.)
'91 MK2 GT2 (alive & kicking)
Register No:1110
could also be the wiring in the tailgate has failed, testing the plug on the motor for power is the best idea.
one thing to remember is that removing the wiring out of the tail gate isnt easy!
the wires must have been inserted into the plug after they were passed through the little hole they go through so disassembly of the plug is required to remove the motor.
- Site Admin
This is why I cut it when removing the one I had out [emoji23]james butler wrote:could also be the wiring in the tailgate has failed, testing the plug on the motor for power is the best idea.
Jack
South East
Jaguar F-Type
South East
Jaguar F-Type
for future reference,Jack92 wrote: Sun Sep 16, 2018 7:03 pmThis is why I cut it when removing the one I had out [emoji23]james butler wrote:could also be the wiring in the tailgate has failed, testing the plug on the motor for power is the best idea.
on the individual connectors inside the plug theirs a barb you press in with a fine flat blade that allows you to pull the wires out without the need to cut them
- scrumpyone
My sparky has discovered there is no power to the wires in the tailgate, so guessing it's fuse/relay. I no longer have the clicking noise when it tries to operate. Anyone got a wiring diagram for this?
Dave
Register No:1110
Register No:1110
- Site Admin
If you no longer have the clicking noise bud chances are it’s the reply.scrumpyone wrote:My sparky has discovered there is no power to the wires in the tailgate, so guessing it's fuse/relay. I no longer have the clicking noise when it tries to operate. Anyone got a wiring diagram for this?
Not sure if this is correct I’ve just found it
Jack
South East
Jaguar F-Type
South East
Jaguar F-Type
- scrumpyone
Cheers matey. I'll pass it on to my man & update on the outcome later this week.
Dave
Register No:1110
Register No:1110
When mine went I’m pretty sure it was this problem and the fix would have worked had I caught up with it in time but by the time I got around to it the motor had burnt out and the fuse blown.
http://www.scirocco.org/tech/misc/rearw ... wiper.html
I replaced mine with a working motor from an earlier car. At some stage VW changed the size of the motor spindle so if your replacement isn’t identical you’ll also need the complete wiper arm etc. from the donor car.
Yes I'am thinking it is the Relay .
No it is not the relay .
Mine has just pooped itself this morning m. Did a single wipe then stopped working, relay still ticking away and can activate the washer jet from the stalk so can’t imagine it’s the tailgate wiring/relay which are the other options I’ve seen suggested on pages. New motor time?
Rear wiper suicide is quite common. They get depressed once they realise the pointlessness of their existence. I always remove them and try to find them a good home in the used parts community.
