Oily spark plug threads
BlackGTX
Post by BlackGTX »
What do you think off this, new plugs rand for about 5 min
Oil or petrol/carbon mix is working its way up the plugs stopping them earthing
Cause?
Re: Oily spark plug threads
shouldnt stop it earthing as the crush ring is making contact with the head and body of plug.
can you post another pic of the tip of the plug?
BlackGTX
Post by BlackGTX »
It makes its way up and onto the seat of the head and under the crush ring
Tips on cyl 1 4 carbon covered 2 3 wet
