My '85 Mk2 has a single jet from each of the two plastic windscreen washer jets.
However, when I look up the part number online, the only versions available have two holes for the water per unit.
Does anyone know the part number for the original single jet units and when (if ever) the two-jet units were fitted to the Mk2s from?
(don't want to remove the part to check the number as it's likely to be brittle with age)
Washer Jets II
Re: Washer Jets II
Sorry can't help with where to buy one but they list 2 part numbers which you may be able to search for?
https://volkswagen.7zap.com/en/rdw/scir ... -231000/#5
Re: Washer Jets II
Thanks mark1GLS.
I'm assuming that the 'A' version of the part must be the two-jet version, with '191 955 985' being the single-jet version I'm after.
Problem is, judging by what's available from the main sources, they all seem to be the two-jet type or none at all, but will keep looking.
Like to keep little details like that as spares to help keep the car looking fresh.
