Fuel gauge issues
Posted: Thu Mar 22, 2018 7:26 am
by ridethesplit
Ok, let's talk fuel gauges! Our gauge is like a deathly slow metranome. It goes from well under empty to just over a quarter and stops wherever it feels whenever it feels like it.
If I put more fuel in, and it gets over half full it goes up to where it should be (I think), but then every corner or hill it has a dramatic dip or raise, before settling again where it should be (I think).
If it drops below half it goes back to being a deathly metranome!
Anyone else had these symptoms. Apparently the previous owner replaced the whole tank and sender.
Re: Fuel gauge issues
Posted: Thu Mar 22, 2018 8:02 am
by mr.brown
Cornering and hill issues are "characteristics" of the system - it's just a plastic float bobbing in the fuel that moves an arm up down a resistor. There are no baffles in the tank to prevent the fuel sloshing this way and that - so that float is constantly moving and affecting the readings.
For the mk1 injection it's actually a clever design trick (or accident) - the fuel outlet is at the rear of the tank - so there's less chance of running out of fuel going uphill. More chance when going downhill but hey, who cares, you're going downhill! :-D
Posted: Thu Mar 22, 2018 8:55 am
by Lukeh17
mr.brown wrote:Cornering and hill issues are "characteristics" of the system - it's just a plastic float bobbing in the fuel that moves an arm up down a resistor. There are no baffles in the tank to prevent the fuel sloshing this way and that - so that float is constantly moving and affecting the readings.
What Mr. Brown said!
Posted: Thu Mar 22, 2018 10:03 am
by Mark H
Mine experiences the same issues, definitely worse with lower fuel in the tank.
