Ok, let's talk fuel gauges! Our gauge is like a deathly slow metranome. It goes from well under empty to just over a quarter and stops wherever it feels whenever it feels like it.
If I put more fuel in, and it gets over half full it goes up to where it should be (I think), but then every corner or hill it has a dramatic dip or raise, before settling again where it should be (I think).
If it drops below half it goes back to being a deathly metranome!
Anyone else had these symptoms. Apparently the previous owner replaced the whole tank and sender.
Fuel gauge issues
Re: Fuel gauge issues
Cornering and hill issues are "characteristics" of the system - it's just a plastic float bobbing in the fuel that moves an arm up down a resistor. There are no baffles in the tank to prevent the fuel sloshing this way and that - so that float is constantly moving and affecting the readings.
For the mk1 injection it's actually a clever design trick (or accident) - the fuel outlet is at the rear of the tank - so there's less chance of running out of fuel going uphill. More chance when going downhill but hey, who cares, you're going downhill!
What Mr. Brown said!mr.brown wrote:Cornering and hill issues are "characteristics" of the system - it's just a plastic float bobbing in the fuel that moves an arm up down a resistor. There are no baffles in the tank to prevent the fuel sloshing this way and that - so that float is constantly moving and affecting the readings.
Mine experiences the same issues, definitely worse with lower fuel in the tank.
Mark
Alpine White
VW Scirocco GT2 (1991)
Membership Number 1296
Alpine White
