Flywheel issues
aaronr
Flywheel issues
Post by aaronr »
Quick q guys does a flywheel from a 210mm clutch work on a 190mm clutch if not does anyone know where I can get a flywheel for the 190mm clutch set up cheep and quick
Cheers Aaron
Re: Flywheel issues
as far as i know it should work as long as the pressure plate will bolt to it on a 1.6/1.8
all you will have is an unswept area of the flywheel where the 210 used to fit try it and see.
just check the friction disk fits onto the output shaft of the gearbox first if it had a 210 before.
