Suspension all depends on what you want to do with the, lower it a little or a lot, not worried about ride quality, how much you want to spend....
I have a Bilstein shocks and Eibach lowering springs which gives a good comfortable ride quality and good road holding, I bought a kit with new shorter bump stops and dust covers.
A few guys on here run the same sort of set up.
Good price as well.
https://www.ebay.co.uk/itm/Eibach-Lower ... 35ecbca24b
If you want to go lower then coilovers is what you want but you will find the ride harder as the lower you go the stiffer it will get and to get a good quality kit with good road manners then you need to spend £600 upwards....
Cheap coil overs are cheap for a reason.... they rattle you and you are to death and can course bump steer if driving on normal roads.
What brakes do you have? Are they the type with the small square pads or the bigger pads and VWII stamped into the calipers?
Fitting a VWII calipers will give you more brake pad touching the disc which helps over the smaller pads.
Making sure the rear brake shoes are probably adjusted makes a huge difference to the feel of the pedal and stopping power, the automatic adjusters do not always Work very well.
Braided hoses help firm up the pedal.
If the brake fluid is more then 3 years old or you don’t know when it was last changed, change it as that’s makes the pedal feel firmer. DOT 4 is what you need.
Bigger brakes can be fitted from Vauxhall’s and bigger master cylinders from 16v Mk2 Golfs if you want to go mad but only really needed if fitting a 200+bhp 20v turbo engine.
Don’t compare the brakes to modern cars with over servoed brakes and ABS as with the Mk1 without ABS you don’t want to lock up the front wheels when stopping as it takes longer to stop if the tyres are not turning but you should be able to lock up the front wheels if you press hard enough.
