South African Clutch Bracket
big_wig_074
Post by big_wig_074 »
Does anyone know where to get these? my bulkhead is at the end of its life, even after a repair, i'd like this as an option as im starting to spend money on the old girl now shes not a daily driver.
Re: South African Clutch Bracket
mark watson
big_wig_074
Brilliant thanks
mark watson
Post by mark watson »
sorry not much on the register , just getting some prices fixed as the pound gained well on the rand and will give a heads up
DJPremier
Post by DJPremier »
I'm still up for one of these. The other thread about it, with pics of it fitted etc. seemed to die a death.
Dave V
BlackGTX
Post by BlackGTX »
Spare clutch cable for me
mark watson
this is mine fitted in the rocco
DJPremier wrote:I'm still up for one of these. The other thread about it, with pics of it fitted etc. seemed to die a death.
Dave V
blame photo bucket for that!!
don't forget you will need to extend the rod linkage to make it work in a rocco ;-)
I've made a couple in the past they're not too difficult to make
mark watson
mine fitted fine james , if you see it is just level with the seam of the bulkhead and does not foul the horizontal piece of the scuttle when the pedal is pressed fully, if it is mounted to high then i see the rod where the splitpin goes in will foul .
