hello, im in the middle wel almost end of converting my rocco to 1.8t, problem i have is the original car was a carb so it dosent have a lift pump, iv tried without one but the pump under tue car is working toooo hard, is their any orher modal vag that uses a pump that would work, as you put scirocco or mk1 golf lift pump in ebay and the prices are ridiculous, in comparson with other models, im on a tight budget you see,
Thank you for any help
Lift pump
Re: Lift pump
Polo from early 90s - the only difference (I think) is the plug points up instead of sideways...
German ebay is the only place you won't pay totally mad prices -
http://www.ebay.de/itm/Benzinpumpe-Kraf ... SwTZtZnu4r
Re: Lift pump
Thank you, thats awsum i can sortthe plug out i will have a brows of the germany ebay, thanks
Re: Lift pump
Also any mk1 Golf cabriolet with fuel injection from mid-84 onwards will have the same pump.
Winston
Re: Lift pump
Hi I have one from g40 for sale that will fit. Failing that you could fit an injection tank.
