Abf kjet conversion not firing
BlackGTX
Post by BlackGTX »
Hello,
Got my abf conversion to the point of turning it over but it wont fire
Ive found that fuel is reaching the injectors but not bein fired. Theres also no spark but thats a seperate issue
Any ideas?
Its an abf running in rocco 16v loom and ecu so shouldnt need the crank sensor according to people online
Re: Abf kjet conversion not firing
if theres allready no spark then that would be your first issue to fix.
no fueling could be anything, i assume your using kjet injection? have you checked fuel pressure is high enough?
monzajake
Post by monzajake »
Is the ecu wired up to the coil correctly ?
Done the same conversion 10+ years ago.
Think without looking 2 black wires to coil 1 green and 1 black to - on battery.
double check the wires on the dizzy loom can get abit loose. Where you based btw ?
scrappy1382
Post by scrappy1382 »
monzajake wrote: Where you based btw ?
hi jake, his car is based in the crawley area.
Scirocco Shane
84 Havanna Brown Storm - 8-)
