Heya, I've got an '88 Scala which is fitted with the 1.8 Carb. It's still using the original pierburgh carb, which up until now has been pretty fine.
Anyway, I've just had quite a catastrophic failure. Basically, the coolant tube running under the inlet manifold has sprung a leak, which then drips coolant down onto the exhaust manifold. This then boils, causing much steam. It also seems to be getting into the exhaust somehow, causing steam out the exhaust.
I don't know quite how, but this also seems to have f***ed the idle, which is now varying from non-existent to far too low. I assume there is some mechanical way in which the carb is controlled via this water temperature, which is now obviously ruined?
Anyway, has anyone experience anything like this? Do I just use generic coolant hose for that area? Is an exact width important? Apologies for my ignorance on the subject, but not an area I've ever had an issue before.
Thanks for any help
Coolant leaking at inlet manifold, screwing everything, 1.8 carb
Re: Coolant leaking at inlet manifold, screwing everything, 1.8 carb
There is a small rubber grommet which the coolant from the head runs into the inlet manifold, the rubber goes hard and brittle over time and breaks.
That could be your problem?
You will need to remove the inlet manifold to replace the rubber grommet and fit a new gasket.
http://www.ebay.co.uk/itm/VW-GOLF-MK1-C ... nrusI0TsGw
Fixing your coolant leak will hopefully solve the running/idle problem.
Thanks, was not aware of that grommet, definitely coming from that area though. I'll give it a go.mark1gls wrote:There is a small rubber grommet which the coolant from the head runs into the inlet manifold, the rubber goes hard and brittle over time and breaks.
Just to be thorough:
The issue is now resolved, the rubber grommet mentioned above was indeed compromised and the seal more generally wasn't looking good. What's more, one of the inlet manifold bolts and two of the exhaust manifold nuts had disappeared. This obviously contributed to the leak, but also explains why there was steam coming out the exhaust at the rear.
Can also confirm, as said elsewhere on the forum, that it is just about possible to remove the inlet manifold in situ, but it is incredibly difficult. In hindsight it may have just been quicker to take the entire head out.
Thanks for the help mark1gls
Glad to hear it's fixed and thanks for the update.
