Scala running problems.
Posted: Mon Aug 10, 2009 9:50 pm
by davywavygravy
Hi i have just bought a 1.8 inj Scala.It starts on the button runs around 1500 revs but as soon as you put the throttle down it nearly dies as if there is a lack of fuel.You can cruise along if you only touch the throttle & dont rev above 3000revs. The previous owner says he has change both pumps!When you rev it in neutral it sounds like a tractor above 3000revs & even warm runs at 1500 revs. Its booked in for next friday but would like to fix it myself if possible.Does anyoe know what could be wrong ????? Thanks David.
Re: Scala running problems.
Posted: Tue Aug 11, 2009 9:02 am
check all the ignition stuff is in good order ( older VWs can be hard on ignition components, particularly if they're cheapo ones)
remove the base of the back set, remove the inspection hatch, then remove the sender/pump unit from the tank. check inside for any signs of water -it will puddle on the botto of the tank. if there is, suck it out with a bit of hose, repair or replace the rusted filler neck (see
here, and curse the previous owners for not cleaning out under the arches ever, so all the crusty mud has built up, held water and accelerated the rust) chuck a new fuel filter on it and then regularly use wynn's dry-fuel for a month or two
