gear box carb, injection
Posted: Fri Aug 07, 2009 11:52 am
by jon89gt
does anyone no if the gear boxes are the same in carb and injection. cheers jon
Re: gear box carb, injection
Posted: Tue Sep 15, 2009 9:34 pm
by monzajake
Yes they are
But try and find out what the code is of the box your replacing as the ratio may well be different along with the driveshaft flange's if it's and early g/box. 90mm or 100mm
codes can be found at the top of page (sticky) and i think there is the flange sizes with the codes as well
