gear box problems
Posted: Thu Aug 06, 2009 6:34 pm
by jon89gt
a srew got into the bell housing and now it has done something, there is gear box oil is all over the road. do i need a new gear box or could it just be the seals or something. cheers jon
Re: gear box problems
Posted: Thu Aug 13, 2009 9:56 pm
by james butler
def new gearbox. hav had this happen in a fiat. the screw will have stood up with the rotatin flywheel and against the bellhousing and punched a hole thru somewhere. get down the scrappy n see if you can find a decent new one.
Posted: Thu Aug 13, 2009 11:07 pm
for what you can pick up a 2nd hand box for, it isn't worth the time messing around trying to fix it unless you're going to do something fun like stick quaif innards into it
