fuel pipe - filler to tank
accyimp
Post by accyimp »
Hi,
Anyone help with a supplier for the 38-40mm flexi pipe to connect filler to tank on the mk1 scirocco (heritage dont list it and silicone seems to be £40 ish per metre)
Andrew
serrow
Re: fuel pipe - filler to tank
Post by serrow »
Hi,
I've just replaced mine on my 85 GTX. Bought one from here: http://www.ebay.co.uk/itm/Mocal-Straigh ... 1077460665 (but too narrow - which I've now got as spare for something, also available in different sizes from - http://www.demon-tweeks.co.uk/motorspor ... -neck-hose),
so bought this: http://www.ebay.co.uk/itm/VW-GOLF-MK1-G ... 1452129239. More expensive but did the job.
Also changed the filler pipe, tank, both pumps, fuel accumulator and all fuel pipes up to the fuel metering head. Cost a few ££££££!
serrow
Post by serrow »
Edit - but mine is a Mk 2!
Village Idiots
Post by Village Idiots »
Try Car Builder Solutions
steve bain
Post by steve bain »
Classic-vw? I got mine off eBay for about 16 quid.I have a mk2
My build thread:
viewtopic.php?f=19&t=14083
accyimp
Post by accyimp »
Thanks all - i'll follow up the leads and update when i'm sorted.
Andrew
where abouts are you based accyimp?
i have a meter of silicone pipe just for the job and can cut you a length to do the job.
let me know how long you need it and i will quote you a price posted.
if you can get your self some mikalor clamps to clamp the pipe with they are by far the best
accyimp
Post by accyimp »
Thanks for the offer James but I've already ordered one off e bay (thanks Serrow) but I'll take the advice on the mikalor clamps.
Thanks for all the help - getting there slowly but surely.
