I trailered the old girl back to work, guy said it hadmt hadn't moved for 5 years, brakes wernt stuck thankfully. She had no battery so connected jemper pack , checked oil n water amd give it ago but only spinning. So i grabs the easy start and it jumped imto into live for a seconds , i grabbed a fuel can and connected it to the fuel pipe directly, took a while for it to get into the carb etc but once lines were full it started right off the key. No water leaks which was a bonus. I trested treated her to £20 of fresh fuel and its champion. It gets pulled out of the garage every day as its a bus depot
