original ride hight
original ride hight
if anyone has ORIGINAL suspension could you measure the distance from the ground to the arch lip for all four corners of the car please.
i want to make a comparison between my lowered suspension and standard 25+ year old suspension
- scrappy1382
Re: original ride hight
hi bud. my car is currently 40mm lower than standard and will measure height as is, and just add 40mm ontop , hope this helps
Scirocco Shane
84 Havanna Brown Storm -
- scrappy1382
60inch at the front and 62inch at the back. this is going by adding 40mm all round by measurements alrady on car. but may be touch higher as my original shocks were stuffed.
hope this helps
hope this helps
Scirocco Shane
- bengould
That is one tall rocco. Lol.scrappy1382 wrote:60inch at the front and 62inch at the back.
Ben.
Cheers for the replys.
I was just trying to work out if lowering the car actually makes much difference to ride height if your going from origenal suspension.
My car doesn't appear to be much lower than before I lowered it, hence why I asked the question
How long ago did you lower the car?
It takes a couple of weeks for things to settle down a little but you should see some difference straight away.
- scrappy1382
my current ride height is now 47cm from floor to wheel arch, front and rear. if you are on the fb site ? i am under scirocco shane. been looking at comparisons lately with regards to everyone ride height and think as a all round low and high, i believe the 'now' height is how it should of been when produced. its good over speed bumps, handles really well, and a proper 'feel' through the steering wheel. my suspension hunting is now complete. ( for now lol )
Scirocco Shane
i lowered it about a year ago now.mark1gls wrote:How long ago did you lower the car?
a few people have said their original suspension gives them a ride hieght of about 60cm from floor to arch so it would mean that yours has dropped by 130mm which would be a lot.scrappy1382 wrote:my current ride height is now 47cm from floor to wheel arch, front and rear. if you are on the fb site ? i am under scirocco shane. been looking at comparisons lately with regards to everyone ride height and think as a all round low and high, i believe the 'now' height is how it should of been when produced. its good over speed bumps, handles really well, and a proper 'feel' through the steering wheel. my suspension hunting is now complete. ( for now lol )
yeah shane ive added you a while back on fb.
- scrappy1382
i dont think its actually that low to be honest.a few people have said their original suspension gives them a ride hieght of about 60cm from floor to arch so it would mean that yours has dropped by 130mm which would be a lot.
Scirocco Shane
- scrappy1382
hey guys. my ride height is actually 57cm, not 47cm ... tape measure now in bin
Scirocco Shane
- unknownmale
did think it sounded rather low!!scrappy1382 wrote:hey guys. my ride height is actually 57cm, not 47cm ... tape measure now in bin
thanks for all the input guys
I went from standard original suspension to a -40mm all round kit. Ride height increased. Lots.
