Good afternoon fellow 'rocco heads.
Driving to and from a show this afternoon, my squeaky front brakes were winding me up. So I thought I would check it out when I got home. The discs and pads are in good condition, so I can only assume it's a shim squeak? It squeaks occasionally when in traffic and no foot brake applied, so that's why I guess shims.
However, I can't find any for sale. Just wondering if anyone could point me in the right direction? Part numbers or websites to check?
It's a Mk2 1.6 GT.
Cheers guys and gals!
Front brake shims
Front brake shims
VW Golf mk1 Clipper Cabby 1.8 - 1988 (now sold)
VW Corado G60 -1992 (now sold)
VW Karmann Ghia - 1969 (now sold)
VW Golf VR6 - 1996
VW Golf Mk2 Type19 - 1984
VW Scirocco Mk2 GT 1.6 - 1989
VW Golf VR6 - 1996
Re: Front brake shims
Back of the pads and the contact points where the ends touch the caliper treated with some appropriate lube? Copper grease or similar hight temp grease
If you have the VWII calipers these fit, you should be able to see them fitted if you have them already?
If so do what Nate says.
http://www.ebay.co.uk/itm/Front-Brake-P ... SwFqJWtIxU
Good shout on the copper grease, didn't think about that. Doh!
I will give that a blast tomorrow afternoon and should that fail then I will pick up the new shims.
Yes, I can see the shims fitted already, just about thought the BBS's. They have definitely seen better days.
Cheers for taking the time to reply and find the part guys. Much appreciated!
VW Golf VR6 - 1996
VW Golf VR6 - 1996
