Brake pads and discs
jdw66
Post by jdw66 »
Quick question can i fit 239x20mm discs with 239x20mm pads into mk 2 scirocco brake callipers or i have i got to fit 239x12mm brake pads.
bengould
Re: Brake pads and discs
Post by bengould »
Pretty sure the calipers and carriers are the same for both vented and solid discs, the only difference is the thickness of the pads that allows the thicker disc to fit.
Ben
jdw66
Post by jdw66 »
Thanks Ben for the reply. As i'm going to be fitting vented discs, it looks like i need the smaller pads, unfortunately.
