Wiper blade sizes mk1 & mk2
Can someone confirm for me the wiper blade sizes:
MK1 (single front wiper)
Front:
Rear:
Mk2 (two front wipers)
Front:
Rear:
Thanks.
Re: Wiper blade sizes mk1 & mk2
Iirc, 16" rear and 19" front
Personally I just get the biggest that will fit.
1lazza
Post by 1lazza »
Hi Ed.
Do not dispose of your original front blade carriers if you still have them, the pivot is slightly offset and I have never been able to find a modern set of blades which fit correctly without overlapping and wearing the screen seal. I recycle the carrier and insert fresh blades each time...Then you get the correct fit, slightly inset towards centreline of car.
//Laurence
Never seen a blade with an offset pivot. I'd have thought it more likely that the blade is bent and the arm needs to move round 1 spline
