Fixed track rod and auto box?
Posted: Sun Apr 03, 2016 12:19 pm
Just a couple of questions regarding my GT.
I went to change the track rod end on the n/s yesterday and found it to be fixed and part of the steering arm, just curious as I've never seen this before?
Presuming you just replace it like a normal steering arm?
When I come to adjust the toe can I just do them both from the o/s which is adjustable?
Also I changed both the lower arms and the n/s required to to take the auto box sump off and lift the engine from it's mounts. Can anyone recommend where to get a new sump gasket from and what oil to use?
