REV counter going right round
Bill
Post by Bill »
Hi all,
Can anyone help me with the problem of the re counter going right round to 7000 when i turn the key,
car runs ok just need to trace the problem, thanks Bill
unknownmale
Re: REV counter going right round
Post by unknownmale »
I'd start of checking the connections at the back of the clocks. I think the rev counter works through resistance, the less the resistance the higher the RPM on the clock, so could be a blown resistor. Best off taking the clocks out and having a play around
unknownmale
I'm not 100% sure about that by the way, just what I would start with
Does it flap about or just hole steady? When the earth strap on mine broke between the rocker cover and coil, Rev counter went nuts
Bill
Post by Bill »
just flies round as soon as you turn the key and the dash lights come on, checked continuity between the plug on the back of the dials and the coil thats ok, will try and get the dials out if we get a dry day the weekend,
Check the earth wire going to the back of the engine rocker cover, if that fails causes all sorts of problems with the dash.
check the earth for the ignition circuit to as i believe the rpm counter works of the negative side of the coil as it pulses?
you may find theres a bad earth in the ignition and its trying to earth through the rpm counter instead (in theory).
Bill
Post by Bill »
Cheers lots to try out.
Bill
Post by Bill »
Had a good look under the dash everything looks and checks out ok,
Is there anyone near Brum how has a set of dials i can plug into to try, cheers again Bill
Do you have an MFA on the car and have you checked the earth in the engine bay going to the rocker cover?
Bill
Post by Bill »
Checked all the earths around the engine bay, no MFA, still trying lots of things at the moment. cheers
im in brum and have a spare you can try.
pm me for more details
Bill
Post by Bill »
Big thanks James for the work tonight. Beer at the National fella, Cheers
Well..... What was the outcome?
Bill
Post by Bill »
Gauge is kaput, but the cost of second hand is unbelievable, anyone got a spare set of gauges at a half decent price.
