Has anyone deleted this?
Not sure how I feel about running oil through my carb, plus mine is old and cracked. Thinking of putting a cork in the airbox and some sort of filter on the end of the hose.
Would rather find a solution that works and doesn't look like it came free on the cover of max power.
Removing the breather hose
- unknownmale
- unknownmale
Re: Removing the breather hose
Ended up going for a Ramair filter and a little rocker cover breather from eBay.
- bengould
If you remove the breather and fit a filter directly to your engine breather you will cover your engine bay in an oily mist.
If you replace the standard air box & filter with a bolt on filter you will loose the hot air feed which helps stop the carb icing in cold/damp weather (i.e. Now).
The best option is to fit an oil catch can onto the breather, and then fit the filter on to that, it will separate the oil from the vapour and keep the engine bay clean. And get a cotton panel filter to fit in the standard air box.
Ben.
Ben.
- unknownmale
Too late now. I don't see how the breather would benefit really, I think the heat in the engine bay and the heater element are enough to prevent icing.
- bengould
The ambient heat is not enough, that is why the hot air feed is there in the first place.
When you open the throttle plate in your carb you reduce the pressure within the carb, this reduction in pressure causes a large reduction in temperature. In cold and damp climates this can and will cause the temperature within the carb to drop below 0°c, freezing the moisture in the air on the inside of the carb. This blocks the fuel jets and stalls the car.
It is most noticeable in the UK over winter on cold damp mornings or driving at night.
At the end of the day, its your car, do what you want. Carb icing is not the worst thing to suffer from, it won't always happen. If it does, wait a few mins and it goes away. It is a bit of a pin in the ass when your late for work and the car keeps cutting out though.
Also, the breather vents the crank case. Which prevents excess pressure building up in the head. Without it you will get oil leaks from the rocker cover.
The air that comes out has a high oil mist content that under normal circumstances goes back into the engine and gets burnt off harmlessly.
If you vent this to atmosphere (in the engine bay) the oil ends up everywhere.
Stick a catch can in between and it collects all this oil and keeps the bay clean. I was surprised at the amount of oil that mine caught.
Again, if you decide not to, that's your choice. It won't harm anything by venting it to the atmosphere but it can get messy.
Ben.
Ben.
- unknownmale
I think the heater element will be enough to prevent any issues.
Thanks for your feedback, I was always going to do it just wanted to know some products people have used.
- unknownmale
- unknownmale
I have no idea why the image has been flipped on the forum - http://dev.lecollective.co.uk/davidholland/IMG_7010.JPG
