83 GTI Electrical gremlins
MRMENDER
Post by MRMENDER »
This is on Huw's car Drove it to the NEC last month when wipers fan stopped working.
Fuse's 10, 11, & 12 Have no power These are Heater fan, Wipers Inc washers & Rear wash wipe.
I have changed the fuse box no difference. I guessed it would be futile as there was no evidence of anything wrong with the old one. I suspect that I have a break in the loom? If I bridge out with wire from a live supply (Horn) all works perfectly.
I can follow the wiring diagram so far! The supply is on track D, question which colour wire is the supply?
Re: 83 GTI Electrical gremlins
Post by mr.brown »
X Contact Relief Relay - tried replacing that? From memory that's the only common thing with power for several devices. I could be making that up though...
DannyH
Post by DannyH »
a faulty ignition switch can cause anything that needs the ignition switched on to malfunction?
Danny
MRMENDER
Post by MRMENDER »
mr.brown wrote:X Contact Relief Relay - tried replacing that? From memory that's the only common thing with power for several devices. I could be making that up though...
What do you mean X Contact relief relay?
Its not the ignition switch just tried my sapre
it's a silver relay, think it's got a 53 marking on it H. I've replaced one on the GTL at some point after a few 'odd' electrical issues.
Post by mr.brown »
Silver, number 17 on it, bottom row, 2nd from left. It's actual function is to cut power to all devices when cranking - but if it's faulty it may be cutting power to those devices all the time.
MRMENDER
Post by MRMENDER »
Thanks Mr Brown :-D
All sorted now thanks found a used but good No17 Relay in my shed.All is now good!
