Rubber Gear Linkage Boot
Don't know German? look here
Mark H
Post by Mark H »
replacing the linkage bushes at present and have noticed the Lower Linkage Rubber Boot is split, does anyone know the part number or have one for sale ??
Mark
Mark
Alpine White
VW Scirocco GT2 (1991)
Membership Number 1296
DT1
Re: Rubber Gear Linkage Boot
Post by DT1 »
If you mean the bit that covers the bottom of the gear stick in the exhaust tunnel, should be 171711195C.
Mark H
Post by Mark H »
Cheers that's the one..
Mark
Mark
Alpine White
You could get them from VW a couple of years ago so may be worth a phone call?
https://www.vwheritage.com/shop/1717111 ... cco-jetta/
Out of stock here at the moment.
http://www.classic-vw.co.uk/mk1-golf-ge ... 5437-p.asp
