Rear screenwash bottle cap?
a57737
Post by a57737 »
Think this is the right section. Apologies if not.
Is there such a thing as a rear screenwash bottle cap? I'm on my third Rocco now and none have had them, just loose fitting plastic trim that doesn't really stop spillage.
Does it just match the front one?
Cheers in advance.
Re: Rear screenwash bottle cap?
Post by mr.brown »
This is the only type. If it leaks, fill it less :-D
a57737
Post by a57737 »
Yeh, that's what I have.
Perhaps I'll try and manufacture something
unknownmale
Post by unknownmale »
Maybe you're just overfilling it?
a57737
Post by a57737 »
My suspension's pretty solid, I think that's part of the problem
Post by mr.brown »
The spoiler "is so efficient that frankly the Scirocco doesn't really need a rear window wiper"
DT1
Post by DT1 »
Great as long as you never slow down or stop!
unknownmale
I might be wrong, but i don't think it's meant to be a sealed unit so wouldn't this cause a vacuum when the water is pumped out. Could always drill a little hole in the cork i guess
a57737
Post by a57737 »
Or get one from a home brew kit maybe
Blueshark
Post by Blueshark »
You could always try this one.
https://www.google.nl/search?q=washerbo ... cgodeZMJUw
It works for the front bottle and has a small hole for the air to get in.
So take the one in front of and try if it fits, if so order a new one for either front or rear .
Joost
