Suspension/ hub help
Chris M GT
Post by Chris M GT »
Hi,
Basically as I'm refurbishing the suspension on my mk2 I've come across a bit of an issue.
I can get the actual hub carrier which connects to the strut/ track rod etc which is in picture 1 however I can't find the hub that the wheel actually bolts to which is the bit in picture 2.
Does anyone know where I might get them brand new?
Regards
Chris
Re: Suspension/ hub help
Post by mr.brown »
Febi 6655 (or 06655)
You can find it on Amazon, ebay etc and elsewhere
I've used this seller many times for Febi parts
http://www.ebay.co.uk/itm/FEBI-06655-Wh ... 0785115621
Chris M GT
You are a star! Thanks a lot mate much appreciated :D
What's wrong with the old ones?
Chris M GT
mark1gls wrote:What's wrong with the old ones?
Nothing mate I just want to get my car to the cleanest/ best it can possibly be within reason.
I won't be binning the old ones I'll be keeping them so in future other rocco's can stay on the road :)
Cool as long as they are not getting binned as they look alright to me, I guess you know you are missing the brake disc cover in your picture? You need to fit it before fitting the hub.
Chris M GT
Ohhh sorry mate I see why you was wondering why I was replacing them now! That picture isn't my car it's off the internet as I needed it for an example, I'd be mad to change them if they looked like that already Haha
:hugegrin: I did wonder... that's cleared up the confusion then. :hugegrin:
big_wig_074
Post by big_wig_074 »
dragging up an old thread, but for information GSF sell these
Get some wickes patio cleaner and put the hub in a tub with enough patio cleaner to cover it up.
This stuff removes rust like no tomorrow, although it takes a few days to fully treat it.
Check out my resto thread if you want to see results.
Just remember this studs acidic so rinse it off thouroughly after and get it painted asap or it will rust up again very quickly
