Bodykit adhesive
Chris M GT
Bodykit adhesive
Post by Chris M GT »
Hi,
I'm new to the forum and was hoping you guys might be able to help me.
I've removed the bodykit inc arches and door bottom panels on my mk2 to clean/ seal behind them aswell as replace a couple of parts and when I took them off there was an extremely strong adhesive holding them on.
Does anyone know if this adhesive is still available or what alternatives I could use for an oem fit?
Regards
Chris
scrappy1382
Re: Bodykit adhesive
Post by scrappy1382 »
i use tigerseal, really good stuff, very sticky and never get it off your clothes, does the job.... other forum uses will say there are many other brands that are cheaper, but i use tigerseal.
Scirocco Shane
84 Havanna Brown Storm - 8-)
steve bain
Post by steve bain »
I use tigerseal. Just dont get it on the shiny paint!
My build thread:
viewtopic.php?f=19&t=14083
would tiger seal work with badges and trim?
ive used double sided tape at the mo which does work but the trip is starting to peel in places.
steve bain
Use 3m stuff for badges and trim. I used it on the door bodykit bits, no problem. Just use 3m, not cheap stuff. Don't use tiger seal other than arches as its basically like silicone sealant and is messy.
My build thread:
duggers
Post by duggers »
A tip with Tigerseal or any other trim sealant/adhesive is to have a rag and some thinners/panel wipe to hand so if you get 'splodge' you can remove it quickly before it cures.
Membership # 432
Chris M GT
Thanks a lot for the help guys,
Much appreciated.
Chris
JOH
Post by JOH »
Any tips on removing the kit over the sills safely?
JOH wrote:Any tips on removing the kit over the sills safely?
i thought these were just screwed on?
