Mk 1 windscreen trim
Hilltop
Post by Hilltop »
Hi, the plastic trim fell to pieces when I took the screens out of my Mk1 and now and I need replacements to re-fit the screens. VW Heritage sell trim for Mk1 Golf and been told this should fit - anyone with experience of this ? Also think I could get s/h alloy trim but have heard this is difficult to fit (it's also a long journey to collect it!) . Any help/advice appreciated.
MRMENDER
Re: Mk 1 windscreen trim
Post by MRMENDER »
Yes the MK1 golf trim will fit. You do need a special tool to fit it though. I got one from Frost restoration parts
I bought some from ebay much cheaper. The plastic trim is not as wide as the original.
Hilltop
Post by Hilltop »
Thanks MRMENDER will try that then.
Hilltop
Post by Hilltop »
Hi all, don't bother with Golf 1 trim - it's not the same. Therefore I'm looking for a good set if anyone has some.
Where did you get the trim from and what is the problem with it?
Hilltop
Post by Hilltop »
Got the trim from VW Heritage. They initially said it would fit but then said it wouldn't - but by then it had been posted out. I was given a refund. It's narrower that the Scirocco's and does not fit well in the grove.
