Bought this from a friend who had quite literally carried it a year ago into his garage with all the engine etc in boxes and bags. Had not been run in 8 years prior to this. Anyway, he got it all together but just "put it together", no tuning or anything, resprayed it tornado red, put it through its MOT and sold it to me about 8 weeks ago (£1500)
I should have put my sensible head on at the time but I couldnt help it, first thing I did was put about 5 mile on it, giving it some serious beans in the process, then off to be resprayed (The red paint job was good, but only as good as a man with a can in a council garage if you know what I mean!)
Came back from paint and then the problems started
Oil leak, now diagnosed as coming from the crankshaft, transmission end. (Seal acquired and also sump gasket as at the time we couldnt figure out which one of the two it was)
Fuel leak, now also diagnosed as the tank itself (on order), cracked at the seal where its welded together
Coolant leak, now fixed thanks to the advice on this thread viewtopic.php?f=9&t=18663
Bonnet release, damn thing just wont pop up, tightened the cable and it releases all the way but someones always got to be by the bonnet to lift it a bit
Auto choke, never intended to keep that anyway as I have a weber 1.6 that ive now ordered the correct jets etc to turn it into a 1.8, always revved about the 2000 rpm, usually at gear change but I found that putting my foot under the pedal and pulling back would make it drop making me think that the cable also might need adjusting.
The jigsaw that is the sunroof! everythings water tight etc and I can ONLY get it to tilt up not slide back, most frustrating thing however is trying to attach the interior trim, it seems too big for the hole! Ive got the manual but to be honest someone may as well tell me how to do it in mandarin! I can attach the spring ok its everything else! Very frustrating!
I forgot the exhaust rattle! Brand new exhaust was fitted prior to purchase but it knocks against the car in two places on low rev, according to my mechanic, easy enough to sort, just needs putting on "correctly" this time!
