Adding a badge on the tailgate
Posted: Sat Dec 20, 2014 9:24 pm
by whiteshark
I want to add another badge on the tail gate . The badge will require the blue rear badge clip lugs but there are no holes for this badge. What size of holes should I drill and is there anything else needed once the holes are drilled to stup rusting when the lugs are fitted.
Re: Adding a badge on the tailgate
Posted: Sun Dec 21, 2014 2:04 am
by DannyH
Don't do it just another potential source of leaks and rust .
Use Tiger seal or something.
I'm sure someone more knowledgeable will soon come up with better advice?
Posted: Sun Dec 21, 2014 8:18 am
by GTXTRA
Decent double sided tape or if they're certain new factory badges they're stick ons anyway.
Posted: Sun Dec 21, 2014 9:57 am
by whiteshark
It's a 16v rear badge. I could cut off the badge plugs and put it on with some scotch double sided pressure tape.
Posted: Sun Dec 21, 2014 10:42 pm
trim tape. the foam stuff. don't use normal flat double sided, it won't stick to the back of the badge very well, as it isn't perfectly flat
Posted: Mon Dec 22, 2014 11:09 am
by whiteshark
Thanks Nate, ordered some and its in the post. Much appreciated, regards Phil.
Posted: Mon Dec 22, 2014 5:11 pm
by GTXTRA
Yes, Nate is right re the foam stuff.
