Adding a badge on the tailgate
- whiteshark
I want to add another badge on the tail gate . The badge will require the blue rear badge clip lugs but there are no holes for this badge. What size of holes should I drill and is there anything else needed once the holes are drilled to stup rusting when the lugs are fitted.
DannyH
Re: Adding a badge on the tailgate
Don't do it just another potential source of leaks and rust .
Use Tiger seal or something.
I'm sure someone more knowledgeable will soon come up with better advice?
Danny
Decent double sided tape or if they're certain new factory badges they're stick ons anyway.
- whiteshark
It's a 16v rear badge. I could cut off the badge plugs and put it on with some scotch double sided pressure tape.
trim tape. the foam stuff. don't use normal flat double sided, it won't stick to the back of the badge very well, as it isn't perfectly flat
- whiteshark
Thanks Nate, ordered some and its in the post. Much appreciated, regards Phil.
