part number for injectors
Don't know German? look here
blackwedge
Post by blackwedge »
Good evening all, I am about to order some new injectors for my 'rocco but want to make sure I get the right ones. The engine code is DX (17891cc). Does anyone know if there are replacements that would upgrade the performance of the O.E ones or should I stick to standard? (It's a long story but the other ones got lost)
Many thanks in advance.
Scott.
Blueshark
Re: part number for injectors
Post by Blueshark »
Depending on threadsize on the injectors you need :
026133551
injector valve / F 53-F-000 001>> 53-G-040 000* / F 53-F-000 001>> 53-G-060 000*
M12X1,5 / DX,KT JH
035133551F
injector valve / F 53-G-040 001>>* / F 53-H-000 001>>
M10X1 / DX,KT JH
Joost
