Crank and water pump pully!!!!!
Posted: Fri Oct 24, 2014 6:06 pm
by rocco robin
Does anyone know where you can get crank and water pump pullys and the 8 Allen head bolts
Have tried vw and as usual DISCONTINUED:(
Vw heritage don't seem to do them
Any help would be greatly apriciated
Re: Crank and water pump pully!!!!!
Posted: Fri Oct 24, 2014 6:16 pm
by chris_d66
Hi
I have a set of 4 brand new crank allen key bolts but cant remember the part number, the pump allen bolts I just use 10.9 15mm allen key bolts.
If you have a 1.8 carb engine
I no longer need my pulley's so if you want the crank, pump pulley and bolts + a set of 4 crank pulley allen key bolts send a PM
Chris
Posted: Fri Oct 24, 2014 7:19 pm
by rocco robin
Thank you for the offer buddy but it's injection so the crank has a built in damper so it will make it even harder to find
Posted: Fri Oct 24, 2014 7:47 pm
by MRMENDER
Hi Robin
The crank pully are 6 MM Allen bolts cant remember the length possibly 8mm? Easily avilable from any engineers merchants. (Websters in Bangor)
Ive a crank pully somewhere you can have, I may have a water pump pully somewhere drop us a PM
H
Posted: Fri Oct 24, 2014 9:04 pm
The allen head bolts was available from VW a couple of years ago so my be worth a phone call?
Posted: Tue Oct 28, 2014 9:09 am
Theyre not made from magical vw only steel!!!!!!!!! You can get them from ANY nut and bolt supplier. Take old one in and ask them to match up!!!!!!!!!!eleven!!!
