Does anyone know where you can get crank and water pump pullys and the 8 Allen head bolts
Have tried vw and as usual DISCONTINUED:(
Vw heritage don't seem to do them
Any help would be greatly apriciated
Crank and water pump pully!!!!!
Re: Crank and water pump pully!!!!!
Hi
I have a set of 4 brand new crank allen key bolts but cant remember the part number, the pump allen bolts I just use 10.9 15mm allen key bolts.
If you have a 1.8 carb engine
I no longer need my pulley's so if you want the crank, pump pulley and bolts + a set of 4 crank pulley allen key bolts send a PM
Chris
Chris
2001 A3 1.8t getting ready to be a donor
2003 Picasso dirty diesel
1995 Golf GTI 16V
1989 Scirocco GT undergoing restoration
1965 2A SWB Landy
1995 Golf GTI 16V
1965 2A SWB Landy
Thank you for the offer buddy but it's injection so the crank has a built in damper so it will make it even harder to find
- MRMENDER
Hi Robin
The crank pully are 6 MM Allen bolts cant remember the length possibly 8mm? Easily avilable from any engineers merchants. (Websters in Bangor)
Ive a crank pully somewhere you can have, I may have a water pump pully somewhere drop us a PM
H
H
The allen head bolts was available from VW a couple of years ago so my be worth a phone call?
Theyre not made from magical vw only steel!!!!!!!!! You can get them from ANY nut and bolt supplier. Take old one in and ask them to match up!!!!!!!!!!eleven!!!
