Flashing red light on temp gauge
Posted: Mon Sep 29, 2014 8:52 am
by daveyg
Hi All
As above over the weekend the temperature gauge is flashing. It normally does this on startup if I remember correctly four or five times and then goes out. However it is continuing to flash. Any ideas?
Pete
Re: Flashing red light on temp gauge
Posted: Mon Sep 29, 2014 10:51 am
by ianaudia4
The light will continually flash if your coolant is low on an injection car, check that first!
Posted: Mon Sep 29, 2014 12:48 pm
by daveyg
Ive had a look and it would appear the coolant was a bit low so will top that up later and see whats what
Thanks Ian
Posted: Thu Oct 02, 2014 12:41 am
by ThomasD
daveyg wrote:Ive had a look and it would appear the coolant was a bit low so will top that up later and see whats what
Thanks Ian
Hopefully it was just low coolant. If it comes back, you can find some more information in this thread:
viewtopic.php?f=11&t=14239&p=113230&hil ... sh#p113230
Posted: Fri Oct 03, 2014 8:57 am
by daveyg
Thanks Thomas
I topped the coolant up and that has resolved the issue but thanks for the link
Pete
