its a E reg no sunroof model in the light metalic blue. no windscreen and thanks to me no headlights or tail lights but motor is still there and the body looks fairly straight and rust free.
It is a carb motor not sure what and it looks like it has a spare carb in the back.
Also this is not mine just may be of use to someone on here.
http://www.kelvedonautospares.co.uk/
mk2 in breakers in Kelveden Essex
- Vonlard
It was meant to be a cheep run around till I finished the Type 1, Now I have 2 projects and an obsession
61 Type 1 Gasser project
88 Scirocco GTX rolling project
Re: mk2 in breakers in Kelveden Essex
Is it the sort of breakers you can walk around?
Can you remember if it still had front wipers?
Do you know of any more breakers local that are friendly to browse around?
thanks, paid a visit today and got the bits i was after. hopefully will make a return visit as need one more bit.
