Hi all!
Am upgrading the master cylinder on my 16v to a 22mm and need to get a resevoir that'll fit underneath the Induction pipe. (Its got the "proper" scirocco 16v inlet manifold) I've got one from a golf GTI which is too tall! I know they made em for the scirocco 16v but can I get one from any other car that'll do the job?
Any ideas appreciated, thanks!
Which brake resevoir ?
Scirocco GTX 16v (conversion) Eibach/KW suspension, Stainless exhaust, Rear discs.
Re: Which brake resevoir ?
Was never happy with the compromised layout on A16 - from when the original 16v was reshelled back in '92 - check the passenger side scuttle area.
this was due to the Autocavan brake bar we had to use on this chassis just forcing the servo a little too far forward to allow the std bottle to fit in correct location. was then always 'one of those things' that never got properly sorted.
17 years later............
it's a mk3 polo bottle.
Cheers for that, GTXtra, polo Mk3 bottle it is then! P.S. wish my engine bay looked as tidy as yours- nice to have a couple of pics of what mine "should" look like! Also, where did you get that strut brace from? Is it specifically for the scirocco 16v?
Regards, Carl
Regards, Carl
cheers - yes the top brace is 16v specific, by Neuspeed.carlosiw wrote:Cheers for that, GTXtra, polo Mk3 bottle it is then! P.S. wish my engine bay looked as tidy as yours- nice to have a couple of pics of what mine "should" look like! Also, where did you get that strut brace from? Is it specifically for the scirocco 16v?
Regards, Carl
not sure if you can get them anymore based on.............http://www.neuspeed.com/products/produc ... pe=ns_euro
check vw vortex or ebay i'd say??
edit - this lot still list one for a 16v though, high quality kit - http://www.autotech.com/prod_susp_stress.htm#front
- Ryan
Got mine from here... http://www.candrenterprises.co.uk/parts.aspGTXTRA wrote:cheers - yes the top brace is 16v specific, by Neuspeed.carlosiw wrote:Cheers for that, GTXtra, polo Mk3 bottle it is then! P.S. wish my engine bay looked as tidy as yours- nice to have a couple of pics of what mine "should" look like! Also, where did you get that strut brace from? Is it specifically for the scirocco 16v?
Regards, Carl
Well it turns out I had a Polo mk 3 reservour anyway-mine from a golf GTI mk2 (same!) The prob is mine won't fit because the induction pipe's not from a 16v scirocco, its the old 8v pipe cut down to fit, so it doesn't quite take the same route as yours! (Will post up some pics when I get a min) Will keep a look-out for the proper bit of pipe on ebay. Got a bottle from an Audi 80 which does the trick so alls good for now!
Cheers for the help though, Carl
