Bad at starting when cold
Hammy-GTX
Post by Hammy-GTX »
Hi am new to the forum :-)
Have had a couple of issues since i bought it in march this year, troubleshooting it made me discover the cog on the end of the cam was the wrong way round and 9 teeth out! Anyway sorted that out so its running smoothly the only problem that's nagging me is that it doesn't start very well, mainly when cold. Pretty much i have to keep cranking the engine with my foot on the accelerator for about 3 seconds until; the engine 'catches' then it will sound lumpy until i give it a rev up to about 3k and its fine. (However it does idle quite high until its up to reasonable temperature, roughly 1.5-1.9k) Sometimes if it doesn't catch first time i try starting it i have to wait for a couple of minutes before trying it again then its even worse to start and frankly is quite embarrassing! i have done a bit of research and might either be too rich or the cold start valve not working?
Anyway its a 89 GTX with the DX engine and K-Jet injection
Cheers Alex
89 GTX 8v
Membership Number: 1304
bensspares
Re: Bad at starting when cold
Post by bensspares »
The problem is leaking injectors. The cylinders are flooded by the escaping fuel. One morning after it has been used the previous day. Remove each spark plug in turn and have a sniff around the hole. if you can smell fuel you have the answer.
Hammy-GTX
Post by Hammy-GTX »
Ill have a look on the weekend, any ideas on a solution?
89 GTX 8v
bensspares
You probably have 1 or 2 leaking. some will be worse than others.
Wait and see whats what first.
Only solution is to replace injectors (approx £30/£40 each).
Try disconnecting the electrical connector going to the 5th injector, this will stop it adding even more fuel when cold and flooding the engine.
You should not need to touch the accelerator when starting the car as if the injectors are leaking you are just flooding the engine.
My injectors are leaking and I've been running without the 5th injector for 6 months now.
Hammy-GTX
Post by Hammy-GTX »
Checked the plugs bensspares; there was a hint of fuel but nothing major. Did what you said mark1gls and it started from cold with no acceleration :-) I'll run it with it disconnected and see what its like.
89 GTX 8v
Hammy-GTX
Post by Hammy-GTX »
Hi have been driving it with it disconnected and is still doing it going to test of the 5th injector on working on the weekend
89 GTX 8v
Blueshark
Post by Blueshark »
The problem is not your 5th injector but the thermo time switch, the big bronze one in the water flange on the front of the cilinderhead above the oilfilter.
Biggest problem is availabilty of it and then for a normal price.
partnumber would be number 16 on http://www.vagcat.com/epc/cat/vw/COR/19 ... 189302/#16 and then depending on engine type
Joost
There is a guide in the Haynes manual on testing the thermo time switch, 5th injector and AAV.
Hammy-GTX
Post by Hammy-GTX »
Thank for the replys ill have a go at the thermo switch soon
89 GTX 8v
Hammy-GTX
Post by Hammy-GTX »
Followed the 'Haynes Guide' to check the concerned items and found that the 5th injector isn't working as there's fuel and 12v getting to it and the thermo time switch works. So it looks like a new 5th injector!
89 GTX 8v
Hammy-GTX
Post by Hammy-GTX »
Just ordered a second hand one from devon dub shack, lets hope it works. A company in Barnstaple quoted me £165 for a new one!!
89 GTX 8v
Hammy-GTX
Post by Hammy-GTX »
The one i got did work but has not fixed the problem. Might try and test the WUR? im guessing this would regulate the amount of fuel going in?
89 GTX 8v
Hammy-GTX
Post by Hammy-GTX »
In the end it was the thermo time switch just to round off this topic, got a second hand one off a kind member for free :) however the 5th injector was broken too.
89 GTX 8v
Glad it's sorted.
