Top Metal Cam Belt Covers.
Posted: Thu Apr 03, 2014 5:40 pm
by G Beats
Now these Metal top Cam Belt covers clip on like the plastic ones and not bolt on ? We our on our fourth MK 2 and in my experience I have never seen one that bolts on unless some one off here can tell me any different ? Thanks all for you help it is more then appreciated.
Re: Top Metal Cam Belt Covers.
Posted: Thu Apr 03, 2014 6:48 pm
by ianaudia4
The metal cam covers bolt on using the 2 10mm nuts on the rocker cover. Both mine have metal!
Posted: Thu Apr 03, 2014 7:21 pm
by G Beats
ianaudia4 wrote:The metal cam covers bolt on using the 2 10mm nuts on the rocker cover. Both mine have metal!
OK sure but do both have to be metal! ? As I would still have the bottom part as plastic and would this still fit OK ? Cheers.
Posted: Thu Apr 03, 2014 7:30 pm
by ianaudia4
Both mine have top and bottom metal covers.
Posted: Thu Apr 03, 2014 8:15 pm
by bengould
Mine has metal top and plastic bottom.
Ben.
Posted: Thu Apr 03, 2014 8:20 pm
by marcus
Mine too.
Posted: Fri Apr 04, 2014 12:40 am
by G Beats
bengould wrote:Mine has metal top and plastic bottom.
Ben.
But how does it fit clips or bolts that is the whole point of what I asked ianaudi which he replied both the last two posts say both so how do these fit please ? Cheers.
Posted: Fri Apr 04, 2014 12:47 am
geebeats wrote:But how does it fit clips or bolts
bolts! already been answered above:
Posted: Sun Apr 06, 2014 6:29 pm
by Mr Funk
Mine's the same
Posted: Mon Apr 07, 2014 12:38 am
by G Beats
Nate wrote:geebeats wrote:But how does it fit clips or bolts
e a
UMM OK but is this a metal top cam belt cover to a plastic bottom cam belt cover ?
Posted: Mon Apr 07, 2014 10:02 am
Mine 1988 DX engine Golf has a plastic bottom cover and a metal top, been like that since new.
Metal top cover is fitted by the 2 nuts also holding down the cam cover at the top and one sort of bolt (allen key head) near the alternator belt.
You can see the hole in the cover in the picture where the bolt goes, it's got a rubber bush around the hole to stop it rattling.
http://www.ebay.co.uk/itm/VW-MK1-Golf-1 ... 1296672417
Posted: Tue Apr 29, 2014 7:28 pm
by G Beats
Right to fit these do you have to replace the rocker gasket ? Many thanks to those who can help.
Posted: Tue Apr 29, 2014 8:12 pm
by bengould
No. The cam belt cover bolts on top of the rocker cover so although you take the nuts off it you shouldn't disturb the gasket enough to have to worry about replacing it.
Ben.
Posted: Wed Apr 30, 2014 6:06 am
by G Beats
bengould wrote:No. The cam belt cover bolts on top of the rocker cover so although you take the nuts off it you shouldn't disturb the gasket enough to have to worry about replacing it.
Ben.
Sorry how do you mean it shouldn't ?
Posted: Wed Apr 30, 2014 7:36 am
by ianaudia4
geebeats wrote:bengould wrote:No. The cam belt cover bolts on top of the rocker cover so although you take the nuts off it you shouldn't disturb the gasket enough to have to worry about replacing it.
Ben.
You would have to do something very wrong to disturb the gasket, it only needs 2 nuts undoing and then doing up again!
