Top Metal Cam Belt Covers.
G Beats
Post by G Beats »
Now these Metal top Cam Belt covers clip on like the plastic ones and not bolt on ? We our on our fourth MK 2 and in my experience I have never seen one that bolts on unless some one off here can tell me any different ? Thanks all for you help it is more then appreciated.
Re: Top Metal Cam Belt Covers.
The metal cam covers bolt on using the 2 10mm nuts on the rocker cover. Both mine have metal!
G Beats
Post by G Beats »
ianaudia4 wrote:The metal cam covers bolt on using the 2 10mm nuts on the rocker cover. Both mine have metal!
OK sure but do both have to be metal! ? As I would still have the bottom part as plastic and would this still fit OK ? Cheers.
Both mine have top and bottom metal covers.
bengould
Post by bengould »
Mine has metal top and plastic bottom.
Ben.
marcus
Post by marcus »
Mine too.
1985 GTL 1.8
G Beats
Post by G Beats »
bengould wrote:Mine has metal top and plastic bottom.
Ben.
But how does it fit clips or bolts that is the whole point of what I asked ianaudi which he replied both the last two posts say both so how do these fit please ? Cheers.
geebeats wrote:But how does it fit clips or bolts
bolts! already been answered above:
Mine's the same
G Beats
Post by G Beats »
e a
UMM OK but is this a metal top cam belt cover to a plastic bottom cam belt cover ?
Mine 1988 DX engine Golf has a plastic bottom cover and a metal top, been like that since new.
Metal top cover is fitted by the 2 nuts also holding down the cam cover at the top and one sort of bolt (allen key head) near the alternator belt.
You can see the hole in the cover in the picture where the bolt goes, it's got a rubber bush around the hole to stop it rattling.
http://www.ebay.co.uk/itm/VW-MK1-Golf-1 ... 1296672417
G Beats
Post by G Beats »
Right to fit these do you have to replace the rocker gasket ? Many thanks to those who can help.
bengould
Post by bengould »
No. The cam belt cover bolts on top of the rocker cover so although you take the nuts off it you shouldn't disturb the gasket enough to have to worry about replacing it.
Ben.
G Beats
Post by G Beats »
bengould wrote:No. The cam belt cover bolts on top of the rocker cover so although you take the nuts off it you shouldn't disturb the gasket enough to have to worry about replacing it.
Ben.
Sorry how do you mean it shouldn't ?
Ben.
You would have to do something very wrong to disturb the gasket, it only needs 2 nuts undoing and then doing up again!
