Hi
Is the mk1 gear selecter mechanism the same as mk1 golf.
1.6 5 Speed box
Mark
Mk1 gear box gear selector issues
Re: Mk1 gear box gear selector issues
Think so, and mk2 scirocco too
- Blueshark
Yes it is, the 5 speed on Golf 1 , Scirocco 1 and 2 are the same.
What is the problem?.
Joost
Joost
Thanks very much
Mark
Mark
Hi
Is the linkage the same as well
difficult to get into gears
Mark
Mark
Yes linkage the same as mk1 golf as is the most of the running gear and engine.
Which model of mk1 do you have? Is it 5 speed or 4 ? Some came with a 4 speed gearbox and have been changed to a 5 speed and maybe the 5 speed linkage not used? Could also be the linkage has not been set up right, there is guide in the Haynes manual with all the measurements etc.
