What you biatches know about fuel tanks, and refurbing them
Rocco-Matt
Post by Rocco-Matt »
Rightio took my tank off whilst i did some welding and doing the disc conversion, when i first took the tank off i thought id just buy a new one, but after stripping another car i realised mine was actually in not bad nick but during that time i just left it sat outside,, took the sender out had a look inside with the torch and its got speckling of rust 10% coverage, any way to get rid of it, i,e something i could pour in or is it now deffo time for a new tank?
cheers
marcus
Re: What you biatches know about fuel tanks, and refurbing them
Post by marcus »
Phosphoric acid, commonly available as various branded anti-rust treatments, if it's only speckling then it would be shame to waste it.
1985 GTL 1.8
marcus
Post by marcus »
And just so's you know, I'm not your biatch! :)
1985 GTL 1.8
Rocco-Matt
awesome cheer fella i say biacth as a term of endearment. I think ill give a few days to dry out, let the petrol vapour evaporate off then ill get started.
marcus
Post by marcus »
Yes, definitely let it dry out! But don't use any heat to help it on its way!
1985 GTL 1.8
Once you've de-rusted the inside, frosts do a tin of fuel tank sealer. Pour in, tape up holes, slosh about for a bit, then pour out. It will help stop the rusticles coming back
Rusticle am your biatch
Rocco-Matt
Cheers thats cracking info guys
