Testing ignition module
marcus
Post by marcus »
Can someone sanity check this idea?
I want to test my ignition module, to rule it in or out of my non-starting problem.
So, I'm thinking if I apply power to pins 2 (ground) and 4 (12v supply), and connect a 12v bulb across pins 1 (coil negative) and 4 (12v supply), and then apply 2v (or should that be 5v?) to pin 6 (hall sender input) the bulb should light...
1985 GTL 1.8
