What would I need to fit the 280 breaks from mk3 golf
Got a chance to get 280mm breaks from the same car my abf is from mk3 golf what would I need to fit them if it's bin done before ?
Re: What would I need to fit the 280 breaks from mk3 golf
I'd guess you'd just need some adaptor plates to mount the caliper to the hub carrier
Golfs with 280 brakes have 5 wheel bolts, what does that tell you!
- bengould
As long as you can get a 4 stud 280mm disk, not a lot.ianaudia4 wrote:Golfs with 280 brakes have 5 wheel bolts, what does that tell you!
Main issue will be mounting the calipers to the hub.
Ben
Can get adaptors from Epytec in Germany for 280mm calipers
My point exactly! MK2 Golf G60's used a 280mm disc and they are 4 stud.bengould wrote:As long as you can get a 4 stud 280mm disk, not a lot.ianaudia4 wrote:Golfs with 280 brakes have 5 wheel bolts, what does that tell you!
Ben
280mm calipers and carriers from the Mk3, plus adaptors, plus 4 stud discs from Golf/Corrado G60 / SEAT Ibiza, some pads, and some 15" wheels
^^^ As above. Just mocked up said gubbins to a mk1^^^
