Gearbox 2nd Gear Crunch
Posted: Thu Sep 26, 2013 9:15 pm
by Jack92
Any ideas guys?
basically when the transmission is cold if occasionally crunches into second but when it warms up it stops?
Re: Gearbox 2nd Gear Crunch
Posted: Thu Sep 26, 2013 9:27 pm
A common problem on these gearboxes, the synchromesh is going on the 2nd gear in the gearbox. Have you checked the oil level in the gearbox? Or even better change the gearbox oil which is often overlooked this might help or make no difference at all but still worth doing as the oil is not that expensive or find another gearbox as it will be cheaper than rebuilding the one you have.
My Golf sometimes crunches if you try to change gear quickly when its cold, I just change gear slowly and its been fine for the last 100,000 miles!
Posted: Thu Sep 26, 2013 9:49 pm
by Jack92
in that case i shall change the trans oil and hope it lasts like your golf lol.
bit lazy this bit as the car isn't at mine its stored in a garage so would prefer to know what to get/look for before hand to save me time a effort.
How do you drain the box? is there a plug? or is it a sumo job and new gasket? and lastly what trans oil do they take?
thanks for all your help mate, on both posts :)
Posted: Thu Sep 26, 2013 10:04 pm
If you don't have a 17mm Allen key this tool is handy
http://www.ebay.co.uk/itm/DRAPER-38323- ... 2a1b1087e5
Very helpful site and loads of info on there, scroll down to the oil change bit.
http://www.brokevw.com/
I'll look into which oil I used, try searching 020 gearbox oil.
Posted: Thu Sep 26, 2013 10:09 pm
by ianaudia4
Gearbox oil is SAE 75W-90
Posted: Thu Sep 26, 2013 10:17 pm
by Jack92
that website is great! how do you find these things lol
and thank ian much appreciated :)
Posted: Thu Sep 26, 2013 10:38 pm
by Jack92
after looking into it a little more via a link on the brokevw site i found that Synchromesh oil normally sorts the issue.
http://forums.vwvortex.com/zerothread?id=3832505
where do i get it? and what am i asking for?
i have found this what is mentions on the other site but it also says its a GM product which this isn't
http://www.ebay.co.uk/itm/Pennzoil-Sync ... 58a1006623
