Any ideas guys?
basically when the transmission is cold if occasionally crunches into second but when it warms up it stops?
Gearbox 2nd Gear Crunch
Jack92
- Site Admin
Jack
South East
VW Scirocco Scala MK2 1.8 Inj
VW Transporter Camper
South East
Re: Gearbox 2nd Gear Crunch
A common problem on these gearboxes, the synchromesh is going on the 2nd gear in the gearbox. Have you checked the oil level in the gearbox? Or even better change the gearbox oil which is often overlooked this might help or make no difference at all but still worth doing as the oil is not that expensive or find another gearbox as it will be cheaper than rebuilding the one you have.
My Golf sometimes crunches if you try to change gear quickly when its cold, I just change gear slowly and its been fine for the last 100,000 miles!
Jack92
- Site Admin
in that case i shall change the trans oil and hope it lasts like your golf lol.
bit lazy this bit as the car isn't at mine its stored in a garage so would prefer to know what to get/look for before hand to save me time a effort.
How do you drain the box? is there a plug? or is it a sumo job and new gasket? and lastly what trans oil do they take?
thanks for all your help mate, on both posts :)
Jack
South East
South East
If you don't have a 17mm Allen key this tool is handy
http://www.ebay.co.uk/itm/DRAPER-38323- ... 2a1b1087e5
Very helpful site and loads of info on there, scroll down to the oil change bit.
http://www.brokevw.com/
I'll look into which oil I used, try searching 020 gearbox oil.
Gearbox oil is SAE 75W-90
Jack92
- Site Admin
that website is great! how do you find these things lol
and thank ian much appreciated :)
Jack
South East
South East
Jack92
- Site Admin
after looking into it a little more via a link on the brokevw site i found that Synchromesh oil normally sorts the issue.
http://forums.vwvortex.com/zerothread?id=3832505
where do i get it? and what am i asking for?
i have found this what is mentions on the other site but it also says its a GM product which this isn't
http://www.ebay.co.uk/itm/Pennzoil-Sync ... 58a1006623
Jack
South East
South East
