kr 16v
steviet_1988
kr 16v
Post by steviet_1988 »
Hey guys.
Quick question. How easy would it be to fit a kr 16v engine into a mk 2 scirocco gtx?
Many thanks
Stephen
86 monza blue gtx, currently in mid restoration.
Bonusrocco
Re: kr 16v
Post by Bonusrocco »
It helps that yours is already injection as your wiring and fuel supply will be much simpler
Theres lots of guides on mk1 golf forum that will apply, theres not much difference in the mk1 & mk2 running gear
The hardest thing i think is finding parts, get a donor car if you can - a mk2 golf 16v being your best bet or mk3 ABF 2.0 16v for a more modern and powerful engine, although clearance with the bonnet can be an issue - someone who knows mk2 better might advise on this
So many plans, so little time
Re: kr 16v
yes - ABF = clearance issues.
