Had my scirocco on the lift in my friends garage today, and discovered that the ball joint had gone on the passenger side. Which explains the knocking noise i've been hearing for the last few months. So obviously i'm going to need a new ball joint and as the wishbone is not in the best of nick plus i don't want to be grinding off rivets and trying to attach a new ball joint to the old wishbone, i've decided to buy the wishbone and ball joint as one complete unit. Couldn't get the parts locally so had to resort to ebay. Found this one . What do you guys think. Would you recommended it. Thanks in advance , john.
http://www.ebay.co.uk/itm/VW-Scirocco-5 ... 35c4dcc8cb
Ball joint.
Re: Ball joint.
GSF and Euro Car Parts are £15 plus £9 for the ball joint!
jdw66
Re: Ball joint.
Thanks for the info. That's much better price wise. will go and check them out.
Re: Ball joint.
You drill out the rivets, not bring them off. The balljoint then slides out of the arm and the new one slides back in, then attach with the bolts and lock nuts that come with it
- go-for-it1
Re: Ball joint.
VWS do Febi wishbones bushes and ball joints. All good stuff. Later Mk 2's have the 17mm ball joint by the way.
http://www.vwspares.co.uk/
2012 BMW 520d M Sport
2013 Golf TDi 140bhp
Member No 1241
jdw66
Re: Ball joint.
Parts ordered yesterday from Eurocarparts. Thanks for all the advice, john.
